2006 Monte Carlo Horn Location
Old Oct 23, 2007 | 07:24 PM
jeffrae's Avatar
Default 2006 Monte Carlo Horn Location
Where is the horn located on this car?
Behind the battery?
I want to replace it.. I could put it on my friend lift and start lokking from the underside.. I don't want to take anything apart untill I know where it is..
It sounds terrible and blows the fuse instantly..
Jeff P
Old Oct 23, 2007 | 10:05 PM
Default RE: 2006 Monte Carlo Horn Location
Not sure if it's in the same location as the '04, but in my '04 it's behind the passenger side headlight assembly. When I removed the passenger side headlight assy. to replace the bulbs, the horns (dual horn) were staring me in the face.
[IMG]local://upfiles/2963/04BF9D9F7F8B4F3CA70A9E1ED1A82334.jpg[/IMG]
[IMG]local://upfiles/2963/19C8D8FD3A5C465F9803A4BBBDA70C80.jpg[/IMG]
Old Oct 23, 2007 | 11:29 PM
couch's Avatar
i'll have a look tommorow at the diagram in the parts catalogue.
Old Oct 29, 2007 | 01:26 AM
FlynhghR's Avatar
Yes, both are located under the passenger side headlight assembly. Remove the white tab near the grille/radiator, then the screw in the channel, the headlight will simply pull out... and there they are, two horns, two wires, two bolts... simple as that.
Old Nov 6, 2007 | 11:39 AM
jeffrae's Avatar
Thanks for the Answers...
Just got back from USVI St Thomas so I was not around checking the forum.. Sorry for the late thanks!!
I will remove my headlight tonight to check it out.
Anyone Know the Quality of Wolo Horns? I don't care what kind of horn it is.. Actually if a loud horn will fit in the Stock Location that would be cool too.
Thanks,
Jeff
Old Feb 15, 2017 | 05:40 PM
Feefee's Avatar
Default Horn
where do I get the horn from AutoZone
Old Feb 20, 2017 | 10:02 PM
Feefee's Avatar
Default Horn parts....
my air bags says service..can I change that myself...
joe111599
Jun 10, 2016 07:01 PM
trich3838
Sep 27, 2012 08:14 PM
hendrick03
Jul 13, 2011 09:31 AM
Love my Monte
Sep 4, 2010 04:49 PM
chaleyss
Mar 7, 2010 09:16 PM
