2006 Monte Carlo Horn Location
Where is the horn located on this car?
Behind the battery?
I want to replace it.. I could put it on my friend lift and start lokking from the underside.. I don't want to take anything apart untill I know where it is..
It sounds terrible and blows the fuse instantly..
Jeff P
Behind the battery?
Jeff P
Not sure if it's in the same location as the '04, but in my '04 it's behind the passenger side headlight assembly. When I removed the passenger side headlight assy. to replace the bulbs, the horns (dual horn) were staring me in the face.
[IMG]local://upfiles/2963/04BF9D9F7F8B4F3CA70A9E1ED1A82334.jpg[/IMG]
[IMG]local://upfiles/2963/19C8D8FD3A5C465F9803A4BBBDA70C80.jpg[/IMG]
Yes, both are located under the passenger side headlight assembly. Remove the white tab near the grille/radiator, then the screw in the channel, the headlight will simply pull out... and there they are, two horns, two wires, two bolts... simple as that.
Thanks for the Answers...
Just got back from USVI St Thomas so I was not around checking the forum.. Sorry for the late thanks!!
I will remove my headlight tonight to check it out.
Anyone Know the Quality of Wolo Horns? I don't care what kind of horn it is.. Actually if a loud horn will fit in the Stock Location that would be cool too.
Thanks,
Jeff
Thanks,
Jeff
where do I get the horn from AutoZone
joe111599
Jun 10, 2016 07:01 PM
hendrick03
Jul 13, 2011 09:31 AM
Love my Monte
Sep 4, 2010 04:49 PM
