2006 fog light question
Old Apr 30, 2009 | 02:06 PM
omb76's Avatar
Default 2006 fog light question
Hi guys,
I have a 2006 MC SS with a burned out fog light. The owners manual listed almost every bulb on the car except that one and said that if the bulb needed is not listed that the car has to be taken to the dealer. I looked under the front end and then opened the hood and looked around and it seems to be a very difficult area to try and access. Has anyone replaced one of these on their own yet? If so, can you supply the p/n needed and any tips to replace it? I hate to pay a dealer to replace something that should be a simple fix.
Thanks!
Old Apr 30, 2009 | 02:35 PM
I think you have to remove the headlight assembly and then you can reach down to the fogs easily.
Old Apr 30, 2009 | 02:42 PM
Hi Member OMB76
Check out the below links 4 additional information.
Good Luck
Assembly Fog/Driving Light Bulb Size : 880 ... 2007 Chevrolet Monte Carlo · 2006 Chevrolet Monte Carlo ...
www.modifiedlife.com/2002-chevrolet-monte-carlo-... - 34k - Similar pages
http://www.modifiedlife.com/2002-che...-size-diagram/
<LI about="r11">2000 Chevrolet Monte Carlo Car Light Bulb Size Guide
Our Chevrolet Monte Carlo light bulb guides allow you to easily replace light bulbs, ... High Mount Stop Light Bulb Size: Assembly Fog/Driving Light Bulb Size : 880 ... 2007 Chevrolet Monte Carlo · 2006 Chevrolet Monte Carlo ...
www.modifiedlife.com/2000-chevrolet-monte... - 34k - Similar pages
[ More results from www.modifiedlife.com ]
http://www.modifiedlife.com/2000-che...lb-size-guide/
<LI about="r12">Chevy Monte Carlo Fog Lights - Hella, Replacement - 2007, 2006 ...
Replacement Driver Side Or Passenger Fog Light 2006-2007 Chevrolet Monte Carlo ... Includes 100-Watt H3 halogen bulb, one lamp and a single bolt mounting system; ..... H12560001 Hella Fog Light 1995 - 1998 Chevy Monte Carlo ...
www.car-stuff.com/mmparts/chevy-monte_carlo/fog_... - 196k - Similar pages
http://www.car-stuff.com/mmparts/che...fog_light.html
<LI about="r12">
<LI about="r12">
<LI about="r13">Chevy Monte Carlo Fog Light - Fog Lights - Partstrain.com
If exorbitant prices keep you from buying Chevy Monte Carlo fog light, ... 6Cyl 3.5L;;
Old May 1, 2009 | 09:08 PM
sonin66's Avatar
you do have to remove the headlight assembly just to get to the fogs. i thought the fog light size was h11's like the low beams. high beams are h9
Old May 2, 2009 | 01:01 AM
draxxis's Avatar
The fog lights are the exact same ones as your low beam headlights, the H11's.. Also, yes you do have to remove the headlight assembly to get to the fog lights.. It isn't hard to do, just one bolt on the top of the headlight assembly, and a white clip that you pull up on.. After that, it's easy to access the fog light bulb area.. Just a matter of twisting it and pulling the bulb out.
I replaced all of my lights with the Xenon bulbs on my 06 LT and love the blue tint and the brightness.
Old May 2, 2009 | 02:21 AM
bwill314's Avatar
or, if you aren't able to do it yourself, most oil change places can do it for you cheaper than the dealer.
Old Sep 11, 2013 | 11:08 AM
Lawpatdad's Avatar
draxxis, did you have to change anything more than just the bulbs to put in the xenons? If so what parts did you use? I own an 06 LT also.
guzzimane
Apr 27, 2014 10:02 AM
mavrickf1613
FWD Tech Guides '95-'07
28
Oct 9, 2012 10:20 PM
USMCdevildog
Dec 2, 2010 04:07 PM
pizzarrhea
Mar 1, 2010 12:12 PM
