2006 clicking noise
Old Jul 16, 2009 | 10:23 PM
DCfla's Avatar
Default 2006 clicking noise
alright .. whenever i turn off my car a clicking noise.. pretty easy to hear starts clicking on the passengers side.. in the area behind the glovebox.. i think it has something to do with the setting of my air conditioner.. because if i turn the car back on while its clicking.. and hit the normal ac button (not defrost) then it will stop.. but on defrost.. it will click
Old Jul 17, 2009 | 08:25 AM
I forget the reasoning, but it's completely normal and I wouldn't worry about it.
Someone may chime in with the exact purpose though.
Old Jul 19, 2009 | 11:46 PM
God_Bot's Avatar
Mine did this for the first time last Thursday after coming out of the movie. Soon as I turned the key it started clicking around the glovebox and I got out and tried to figure out what the hell it was. Never figured out as it stopped after a few seconds.
Old Jul 20, 2009 | 11:42 AM
alabamamonte's Avatar
its your ac. Mine did the same thing. It was undr warranty so they fixed it free but it took them like 4 hours because it is really hard to get to. It has something to do with the dual climate control.
Old Jul 25, 2009 | 09:19 AM
monte07's Avatar
with mine it was the rack and pinion and the power stering pump that was doing it. power stering itermedeatly stoped working and put a strean on the rack and pinion and took out the rack and pinion when the power stering pump was replaced thank. god at the time i had a warrentythe rack and pinion is lick pushing 1600 dallers alone no install
Old Aug 27, 2010 | 01:00 PM
spitdogger's Avatar
Mine is doing this also. Its the louver that switches from recirculate to outside air. Possibly a stripped gear or its hung up.
Old Aug 27, 2010 | 01:37 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Good info. Mine did this yesterday for the first time. Now I don't have to worry about working on it all weekend.
Old Aug 27, 2010 | 04:35 PM
Brembo's Avatar
AC issue. We've had it fixed on the passenger side, now the driver side does it. Its something about the control system and a 'tiny piece that breaks off and prevents the actuator from moving', as per the service dept...
Old Aug 27, 2010 | 07:51 PM
TheMonteMan's Avatar
this has been encountered before. its an ac piece. if its out of warranty its expensive to have the dealer do it. this guy on ls1tech did a how to video on how to replace it. ill find it and post the link. took me a bit to find it. heres a link to the thread. the videos in the first page. good luck with it. doesnt look very hard to do.
http://www.ls1tech.com/forums/ls4-fr...c-fix-vid.html
Old Aug 28, 2010 | 08:13 AM
spitdogger's Avatar
Thanks for the video link. I think there are actually two actuators on the passenger side. One is a blend door actuator like the one in the vid and the other is a recirculation vent actuator. I think they are all the same part #. Mine actually clicks when I hit the recirculate button and shut the car off. Thanks for all the info. I ordered an actuator from gmpartsdirect.com
