2005 Monte SS supercharged problem
Old Jun 22, 2011 | 11:46 PM
mana40222's Avatar
Default 2005 Monte SS supercharged problem
Today I started my car, was sitting and the car died while at idle. It has been dying intermittently, so I thought nothing of it, until I drove about a mile. It felt like someone was behind my car kicking it, almost as if it was going to stall, but was intermittent and only happened about every 2-3 minutes. But did not improve, only got worse. My RPMs would rev up to about 2 when it happened. It felt like it was going to die on me while I was driving it. I would accelerate a little more, and it would stop but then would reoccur. Any ideas as to what could be going on?
Old Jun 23, 2011 | 06:00 AM
Either your MAF sensor or your IAC sensor, both on the throttle body.
Old Jun 23, 2011 | 09:11 AM
nitehawkjcb's Avatar
Might as well change your fuel filter, air filter, spark plugs, and wires while you're at it
Old Jun 23, 2011 | 09:57 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Most likely the IAC is malfunctioning or stuck open and needs to be replaced
SSmokybear
13
Apr 24, 2013 12:52 PM
weizie
May 16, 2009 08:35 AM
