2004 monte carlo ss random stall
Old Mar 7, 2011 | 07:47 AM
04mc3.8sc's Avatar
Default 2004 monte carlo ss random stall
ok my moms monte just developed this problem. it will start and run fine still has good power,if you drove it you would think nothing is wrong with it until it just dies no sttuter or jerk or anything it just stops running like you shut the car off.but it does start right back up and run normal and you could go 100ft or 30mi before it dies again. i replaced the crankshaft position sensor allready and it did nothing. i thought with this new computer controlled B.S. it would throw a code but none are present.any thoughts?
Old Mar 7, 2011 | 07:51 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
I would start with the connection to the computer. This seems to be a short and if there is no codes thrown, I would start there. Good luck!
Old Mar 7, 2011 | 12:39 PM
nitehawkjcb's Avatar
Ensure the wiring to the crank sensor isn't damaged. If that's not it, check your ground by the ICM. If all that is good, your ICM (Ignition Control Module) is probably going bad.
Old Mar 7, 2011 | 01:22 PM
04mc3.8sc's Avatar
the ses light finaly came on and i got po102 (maf sensor low imput) and po135 (o2 sensor heater circuit range problem up stream) could these cause the problem im haveing? im going to replace the maf and o2 sensors but will they cause it?
Old Mar 8, 2011 | 10:23 AM
04mc3.8sc's Avatar
well i replaced the csps,maf and o2 sensors and so far i think its fixed. grand tottal for parts $250. what is with the security torks head? why not regular torks?
Old Mar 11, 2011 | 06:10 PM
ChucksMonte's Avatar
I was gonna say MAF but i see u got it. my friend at work had a very similar problem on his minivan, it would just die for no reason. It was a bad MAF.
Mick Pafford
Oct 24, 2013 11:55 AM
Mick Pafford
Aug 27, 2013 10:15 PM
mrl390
May 6, 2009 08:48 PM
mksiler
May 14, 2008 08:08 PM
shawner
Mar 8, 2006 03:27 PM
