2004 Monte Carlo Ls l64 swap icm issues
Old Apr 30, 2017 | 11:19 AM
Zac Henes's Avatar
Default 2004 Monte Carlo Ls l64 swap icm issues
I swapped my running 3400 for the l67 from a 02 ssei. I used a 02 mc ss wiring harness. Tried to use 02 ss pcm. No security light no crank. Tried a 03 gtp pcm same thing. I plan on buying an pcm to work with my car. Back to problem at hand I figured out it was a no spark issue. Tested the pink wire at the icm and it is reading as a ground. Went to test ground and I'm getting nothing there. So my question is, is the wiring for the pcm different I have checked the fuse that it runs off of and it is getting 12v
Old Apr 30, 2017 | 03:03 PM
A few things jump out at me.
A 2002 Monte Carlo wiring harness will not have all of the same sensors as an L67 wiring harness. Have you spliced in extra connectors?
You need a PCM programmed with your VIN.
Old May 2, 2017 | 04:50 PM
Zac Henes's Avatar
I extended that Evap perge wires and that's all I really had to do got the rest to work I don't have any loose connectors nor do I and loose pigtails. I understand that I have to get the pcm flashed but it's SHOULD have power to the icm without the right pcm
Old Jun 11, 2017 | 09:38 PM
Zac Henes's Avatar
Got the Icm to have power and ground. The crank is receiving power just not sending signal. I replaced the cps still no spark
