2003 SS Dead
Last week while driving from work, my car started sputtering like it was running out of gas. There was gas because I just got some from the gas station before it happened. My gauges for the gas and my coolant temp were reading empty and cold. They kept jumping. I got off the road, cut the car off and it wouldn't restart at all.
I had it towed home and tried tinkering with it. No luck. There's no power whatsoever in this car. Battery is less than 6 months old, alternator is less than 6 months old since I changed it. I've tried charging the battery, and that doesn't do any good. Any input on what this could be? Is it the PCM? The car has 212,000 miles |
It most likely is that exactly, Sometimes if you disconnect the Battery completely and leave it overnite it might reset something. And you get another chance.
Otherwise you will need a new one. Might find one at a salvage yard?? good luck!!:thumbsup: |
Thanks for confirming that. I haven't tried leaving the cable off overnight but I'll try that and see what happens. And if not, then I'll take the next step of getting another PCM or a car haha.
