2003 LS keeps shutting off
Old Sep 29, 2015 | 10:42 AM
THAV's Avatar
Default 2003 LS keeps shutting off
I have a 2003 LS that all of a sudden shut off on me yesterday while driving. When I say shut off, the engine just died. I tried restarting it and it would turn over and then shut off. I got it towed back to the house and replaced the fuel pump because I was having issues with the sending unit and thought that would do the trick. I turned the car on and it started up without any hesitation and ran in park for about 10 minutes. As soon as I backed out of the driveway and pulled down the street, the engine shut off again. It still shuts off when I turn it over like yesterday. Another thing I noticed, is the RPM gauge is jumping all over the place when the motor trys to stay on.
Anyone have any ideas what might be causing this?
Old Sep 29, 2015 | 10:25 PM
nitehawkjcb's Avatar
Probably a sensor problem. Commonly, the MAF does stuff like that without throwing a check engine light. However, it could be the crankshaft position sensor, cam sensor, ignition module...
Old Oct 6, 2015 | 02:58 PM
THAV's Avatar
Luckily it was just a tune up. I replaced the spark plugs and wires and it runs like a champ now. Thanks for the input!
