6th Gen ('00-'05): 2003 cooling fans not turning on
Old Jun 27, 2017 | 04:05 PM
  #61
evilee530's Avatar
Apologies if this has been covered, the link I sent. I didn't have a long enough lunch hour to read the 6 pages on this thread.
Old Jun 27, 2017 | 04:09 PM
  #62
FFGURU's Avatar
I wish my issue was a relay, I have replaced them all and have even replaced the bcm. Which caused me to get fan operation, just not full time operational use.
Old Jun 27, 2017 | 04:16 PM
  #63
evilee530's Avatar
What is the BCM - I have a feeling my problem is deeper than a relay switch but if that switch is causing the overheating OR can it cause overheating... I seriously don't want to run the heater all summer
Old Jun 27, 2017 | 06:26 PM
  #64
FFGURU's Avatar
The bcm controls a lot of electronics in the car, usually you would experience a ton of electrical problems with a bad bcm. It would usually throw a code as well.
Old Jun 27, 2017 | 07:30 PM
  #65
evilee530's Avatar
So it looks like for me, as of now, my air compressor is out... fan isn't turning on it. I was able to get the radiator fans working though. I didn't know they were out but the O'Reilly guy was a big help. Still no AC and one window bolted up UGH!!
The only thing that overheating may still be is a temp sensor or something like that. Sorry I don't know all these terms.
Hope you figure it out FF - I'm sweating too if it helps
Old Jun 27, 2017 | 07:33 PM
  #66
evilee530's Avatar
Would these electrical issues include blinkers that work when they want and a fuel gauge that say completely full or empty? Just curious since the car has 233K on it.
Thanks
