2001 SS Starting and Turn Signal Problem
Old Oct 16, 2009 | 11:41 AM
Plengr's Avatar
Default 2001 SS Starting and Turn Signal Problem
I have a 2001 Monte SS which recently is showing a couple problems. The first was the turn signals stop working or don't activate once in awhile. I'm guessing the flasher or switch, hoping for the later but would take any thoughts as I haven't worked on this car much.
The second started a few weeks ago. The engine is hard to start (does alot of cranking) and when it does it often dies. Once it's running it seems to be fine
thanks
Last edited by Plengr; Oct 16, 2009 at 11:54 AM. Reason: Make the symptoms more clear
Old Oct 16, 2009 | 11:43 AM
Turn signal could be the multi-function switch yes.
Old Oct 16, 2009 | 02:05 PM
Plengr's Avatar
I did some more digging online and found that the FPR can be a common cause on the 3800. I pulled the vaccum line off and ran it. Didn't see any fuel coming out of it so the diaphram is probably good. I then pulled the return line off and just flipped the key to on for a second(engine was off). Fuel shot right out of the return. Should the FPR be closed when there is no vac from the engine? It seems I've been told that in the past but wanted to confirm. If the FPR is leaving fuel go by and dropping pressure it would definitely explain the hard start.
Old Oct 19, 2009 | 01:12 AM
ssblackbeauty's Avatar
the problem with your turn signal is the hazard switch. go to the dealer and get the whole switch assembly for like 50 dollars and problem solved.
Old Oct 23, 2009 | 08:47 AM
Plengr's Avatar
Default Hazard Switch
I was out of town but got a switch on order and I replaced the FPR before I left. No problems starting since the replacement. We'll see if it holds. Thanks for the tips!!
YeahDoggie
Aug 3, 2013 05:54 PM
ADAPPJ28
Feb 1, 2013 03:11 PM
01navyss
Jul 24, 2012 05:53 AM
Skeletal Crow
Jul 22, 2011 11:56 AM
85monte4.3
Dec 7, 2010 09:29 PM
