6th Gen ('00-'05): 2001 fuel pressure regulator vacuum line
Old Mar 9, 2020 | 04:36 PM
Angus63's Avatar
Default 2001 fuel pressure regulator vacuum line
Hi, while changing plugs and wires on my 2001 monte carlo ls 3.4. ( which were original and a witch to remove), I accidentally severed the vacuum line between the fuel pressure regulator and intake manifold. Having trouble locating the part. Any help? Thank you
Old Mar 9, 2020 | 08:19 PM
Angus63's Avatar
Default News
Did some more research and learned that the fuel pressure regulator vacuum line is also connected under the MAP sensor and is listed under a MAP Sensor vacuum line. Found one online @$7 USD. All better...
Raceman005
Sep 8, 2017 08:02 AM
Sparkym
Apr 22, 2015 09:57 PM
armando b
Feb 16, 2015 01:55 PM
yellowmonte
Feb 23, 2010 08:38 AM
jts01ss
Oct 20, 2008 09:01 PM
