2001 coolant leak
Old Jul 14, 2006 | 06:12 PM
greg fell's Avatar
Default 2001 coolant leak
Are these prone to leak at certain areas? I cannot find the leak from the life of me. I've visually inspected quite a bit. I have replaced the lower radiator hose. It leaks from the passenger front side of the car.
Any help would be great.
Old Jul 15, 2006 | 02:17 AM
NYCRISS's Avatar
Default RE: 2001 coolant leak
What year is the car? What motor?
Old Jul 15, 2006 | 04:00 AM
The Black Machine 29's Avatar
i had to replace my intake gasket....
1300 bucks at the stealership.. lol
Old Jul 15, 2006 | 10:07 AM
montejass's Avatar
From my understanding this is/has been quite common with the 3.4L...
Old Jul 15, 2006 | 12:30 PM
NYCRISS's Avatar
Yes it is quite common for the intake to leak. There is an updated lower intake gasket designed to prevent this condition. You can tell the difference from the 2 by the color of the embedded gasket. The original one is orange. The updated one is teal.
Old Jul 15, 2006 | 02:56 PM
greg fell's Avatar
its a 2001 with the 3800. do the intake gaskets leak on the 3800's also?
Old Jul 15, 2006 | 03:12 PM
NYCRISS's Avatar
Yes they do tend to leak at the corners. Look down below the intake at all 4 corners. Also check to see if the oil looks milky and the coolant as well.
Old Jul 15, 2006 | 03:43 PM
greg fell's Avatar
looks like that is the problem guys! thanks!
Old Jul 15, 2006 | 06:11 PM
montejass's Avatar
ORIGINAL: greg fell
At least you caught it before it got worse!!
Hey NYCRISS, what is the story behind the factory applied leak tabs being used on these engines?
I am still pulling black goo from my cooling system. I am kind of worried that it may cause problems down the road...
Old Jul 15, 2006 | 07:53 PM
mickey's Avatar
you and me both but im going to change my hoses and flush the crap out when i do. Going to kool flex hoses in the spring. on all of the cooling system
And gettign completely away from DEXCRAP!!!!!
