2001 coolant leak
Are these prone to leak at certain areas? I cannot find the leak from the life of me. I've visually inspected quite a bit. I have replaced the lower radiator hose. It leaks from the passenger front side of the car.
Any help would be great.
Yes it is quite common for the intake to leak. There is an updated lower intake gasket designed to prevent this condition. You can tell the difference from the 2 by the color of the embedded gasket. The original one is orange. The updated one is teal.
ORIGINAL: greg fell
looks like that is the problem guys! thanks!
Hey NYCRISS, what is the story behind the factory applied leak tabs being used on these engines?
I am still pulling black goo from my cooling system. I am kind of worried that it may cause problems down the road...
