2000 monte carlo ac and heater wont blow out vents
Old Oct 4, 2010 | 08:18 PM
sunshine1979's Avatar
Unhappy 2000 monte carlo ac and heater wont blow out vents
my 2000 monte the ac and heater wont blow out the vents could anyone please help, we have replaced the blower motor because it went out, we have also replaced the resistor, control ****(blower only comes on on 5) and still wont work. thanks
Old Oct 5, 2010 | 04:43 PM
chimaira04ls's Avatar
I have had this happen to me, I kept switching the directional ****, vents to floor and to defrost, back to vents and so on. It sounds like there is a little motor switching around the direction of the a/c or heat output. It fixed it for me, one must have been stuck or something. I'm not an expert, but sounded like a familiar problem I had. Good luck!
Old Oct 6, 2010 | 01:24 AM
lucian*91's Avatar
if your motor only works speed five, your resistor pack is bad. as for the blend door. your module could be ad and not turning the door, or door is stuck
Old Oct 6, 2010 | 11:53 AM
we have replaced the resistor and now the temperature **** control panel now the blower wont come on at all I am fed up with this car.
Old Oct 6, 2010 | 07:45 PM
enibum's Avatar
More than likely the blower motor has wore out the brushes and you need a new blower motor. Very easy to fix. behind the glove box and accessable from under the dash. Just remove the kick panel where the floor board light is. Unplug the wire from the motor and remove three screws.
Old Oct 28, 2010 | 06:50 AM
Update:
we have taken our monte to the autoshop at college and they have found problem it is the ignition starting system
joe34
Oct 10, 2013 10:33 AM
Dustin LaRoche
Jun 1, 2012 08:21 PM
Dustin LaRoche
May 28, 2012 07:59 PM
wrluna
Nov 17, 2011 07:34 PM
Cowboy6622
Nov 12, 2010 11:03 PM
