1985 monte carlo power window problems
Old Mar 20, 2010 | 09:14 PM
mightymouse305's Avatar
Default 1985 monte carlo power window problems
i have a 1985 monte carlo ss i recently took the drive side door off to put new pins in it. i have hooked up all the wires back up but now neither of the windows will go up or down. i have bought a new motor and hooked the wire into it and still nothing, the new one still did not work. i cannot figure it out, any help please.
Old Mar 23, 2010 | 11:16 AM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
assuming the window worked before, I would check the voltage going to the line, and also to the switch. Then follow the wires and make sure everything looks good. Also check the fuse to make sure nothing didn;t blow.
Old Mar 24, 2010 | 08:50 PM
the switch has 12 volts the hook up that hooks into the motor even has 12 volts the fuse for the windows is even good ive checked all this stuff i still cant igure it out.
Old Mar 26, 2010 | 08:05 PM
Justin Knight's Avatar
if it all worked before you did the hinges something isn't hooked up right or is making a bad contact i would think some of the wiring harnesses are tucked pretty tightly into the kick panels. if you already gained access to the window motor connector and a test light will light when in place between the two terminals that would indicate a bad motor if it has 12 volts and ground through the connector it has to work. an 85 isn't as complicated as some newer cars its cut and dry power and ground to go down and switch polarity through the switch for back up.
MCJO
Nov 16, 2013 09:21 PM
MySS
Aug 10, 2012 08:58 AM
tray23phillips
Jan 3, 2012 12:30 PM
teddy620_2000
Oct 9, 2007 06:15 PM
cody072891
May 12, 2007 12:24 AM
