1975 Monte Carlo Wiring Diagram
Old Dec 23, 2006 | 10:08 PM
SleepyEG's Avatar
Default 1975 Monte Carlo Wiring Diagram
Hey
Im having some troubles with the Cluster and Ignition.
Replaced the Cluster and when installed. Turned the car on. Everything is fine. Dash lights didnt work. so i tapped into a spare fuse in the fuse box. Got that working. Now you start the car. runs normaly. Go to turn it off. and well it kept running. Key ignition wouldnt turn the car off. had to choke to shut off.
I searched the net and everything i found was having to order a whole manual
Im wondering if anyone knows where i can find a quick diagram reference for the interior fuse box and ignition system
Thanks in advance
Old Dec 23, 2006 | 10:28 PM
88ss408's Avatar
Default RE: 1975 Monte Carlo Wiring Diagram
well i got the wiring diagram here but i dont know how to get it to ya
Old Dec 24, 2006 | 05:29 AM
SleepyEG's Avatar
scan it?
if its on a website you can link it?
Old Dec 24, 2006 | 09:27 AM
88ss408's Avatar
its in one of my books and i dont have a scaner
Old Dec 26, 2006 | 12:11 AM
SleepyEG's Avatar
hm fair enough
Any ideas as to what couldve caused this?
Im thinkin maybe somehow the ignition key switch, something couldve slightly hit it while taking the cluster and/or dash panel face out.
Its just so weird. Starts fine.
Key turns properly. just doesnt shut off
Old Dec 26, 2006 | 01:03 AM
djhixter's Avatar
check to see if your linkage may be bound up between the ignition switch and the lock cylinder. also you may have to readjust the ignition switch just a tad. on the ignition switch itself, it should be slighty slotted for adjustment. your lock cylinder may be defective as well. also being a '75, you won't be able to scan it.
9teen70monte
Oct 24, 2012 04:36 PM
janu99
Oct 15, 2012 10:54 PM
Feb 9, 2012 09:31 PM
mhallen13
Nov 29, 2010 12:20 AM
streetstock racer
Jul 15, 2008 03:08 PM
