Opinion Needed: 1972 monte repair advice needed!
Old Sep 5, 2016 | 04:54 PM
Lamboproduction's Avatar
Default 1972 monte repair advice needed!
So far this is the problem list with the monte
• A/c compressor does not engage even when jumped,
• a/c control panel is off the dash its put together and wired just not screwed on
•horn relay does not work so it needs a new one
•a/c needs duct work put back in it i have that
•windshield washer pump needs tubing and washer nozelz
•rear window leaks at seal
•rear window also has no water drainage resulting in sitting water in the groove behind metal trim
•paint needs too be redone because it has bubbles everywhere
•there is 2 rust holes golf ball size in front drivers side fender
•and no turn signal indicators for the dash
How much would a ball park price be too have someone just fix it all so i dont have to? Thank you!!
Old Sep 6, 2016 | 09:52 PM
shawn parker's Avatar
you will be much better off breaking it down into smaller steps, then some you can do yourself and shop the others for a deal or a shop you trust
