Maybe a minute amount highly noticeable, but i know when I push on the accelerator it gets faster not louder and if it's in park idling I get a low oil pressure warning
Ok, so I asked earlier about your oil (type, usage and filter#) I will add to those questions with is the level at the full mark on the stick?
Yeah everything checks fine I just did an oil Change. Penzoil n a regular filter. I found small amount of metal shavings on the plug tho
Originally Posted by Mozdzen23
(Post 639603)
-What weight oil? -What filter and part #? -how much oil do you add between oil changes? |
So I have parked my monte until I can resolve this issue. I'm I going to have to get to the lifters to see which ones are bad? Also what lifters will I need to replace them? Can someone look on rockauto n post the link. I have the DOD
(Post 640203)
Yeah I'd rather just fix the DOD right now. I'm thinking about trading it in but not sure yet. So any idea what lifters/rollers I'll need?
Ls7 ones work I believe. Call Brian tooley they could get you set up
Idk who Brian is.... But I kinda need to know which kind to buy would be helpful!
(Post 640298)
