03 Monte Need Help
Old Apr 4, 2011 | 05:50 PM
03Montepacecar's Avatar
Default 03 Monte Need Help
ok my problem is that it is not accelerating like it should, it takes for ever to get up to speed. when i go to pass someone it will downshift but then the rpms will just slowly go up, there is no codes showing and idk what to do to figure this out. it seams like that it is getting worse the more that i drive it too. only thing that i can think is that has to be a sensor somewhere but not sure what one either the tps sensor or maf sensor? if someone knows what i am talking about please help me out here. thanks
Kevin
Old Apr 4, 2011 | 06:04 PM
NovaSS369's Avatar
I'm thinking your catalytic converter may be plugged?
Old Apr 4, 2011 | 06:14 PM
X2 check your cat...
Old Apr 4, 2011 | 07:04 PM
is the only way to test the cat is to take it off ?
Old Apr 4, 2011 | 07:06 PM
If you need to replace your cat, I would use that as an excuse to do the exhaust system upgrade that is popular on the 6th gen Montes. High flow cat, downpipe replacement, U-bend delete, and cat-back exhaust system of your choice.
But if your cat converter is plugged, something usually happened to cause it in the first place. Make sure that issue is fixed first. Or you'll be ruining your new cat too.
Old Apr 4, 2011 | 07:31 PM
it only has 88k on it and when i had my 02 monte ss 2 days after i bought the thing the cat went bad so i got it fixed under warranty but when that happened i could not get the car to go any faster than 40 miles per hour. could it be the cat again in this car??? they do have 100,000 mile warranty on the cats so i would just do that. this is just my daily driver and i don't need to have another modded car lol i have my Grand Prix GTP lol.
Old Apr 23, 2011 | 08:19 PM
cbenez1's Avatar
No remove the 02 sensor above the cat.(In the exhaust manifold) If your cat is clogged it will run like it should with the sensor out just alot noisier. Just went through the exact same problem on my 03. My solution was to gut it but now inspection is coming up so I need to install a new one.
Old Apr 23, 2011 | 08:29 PM
Its prob the cat mine just crapped out on me, suprising it was around the same milage as my truck wen they went
Old Apr 24, 2011 | 11:39 AM
it was the cat got it fixed and not i found out that my resinator is all rusted out so that is coming off next lol
Old Apr 27, 2011 | 10:29 PM
NovaSS369's Avatar
Good we need her at full potential for the Wbody Tour!
