6th Gen ('00-'05): 02 SS - P0102 Code - Bogs under load
Old Oct 14, 2016 | 06:52 PM
BravoWhiskey's Avatar
Default 02 SS - P0102 Code - Bogs under load
I have an 02 SS that is throwing a P0102 code. I have cleaned the MAF Sensor and even replaced it. Neither fixed the issue. I took the new MAF back. The car will not accelerate well at all. It bogs down when you put your foot into the gas at all. Can only manage about 25mph up hills. Any thoughts or suggestions would be great. Thanks!
Old Oct 15, 2016 | 06:35 AM
user 35764368's Avatar
try cleaning the air intake temp sensor also. and look for air leaks on the intake boot[tight clamps] and where it connects to the airbox and throttle body, make shure the clips are secure that hold the air filter inplace and that you have clean air filter.d
an also inspect the connector to the MAF for frayed or broken wires.
if all that checks out id suspect a clogged catalytic converter..... maybe that would throw off the intake flow information enough to throw that code?
