02 SS cooling fans not working.
Old Aug 23, 2011 | 04:22 PM
TraviSS's Avatar
Default 02 SS cooling fans not working.
Got problems on my 02 SS. I've searched all the related threads without an answer found yet.
The cooling fans quit working yesterday. I got it home without getting too hot. Last night I went out to try to fix it. I replaced the 3 relays and all the fuses under the hood are good. I tested the new and old relays and all checked out the same, 85 to 86 on old and new relays read approx 90 ohms. No CEL has come on. I have a code reader and did a 'live data' read when the motor got warm. I got the water temp up to 233 and the fans never kicked on. I replaced the thermostat a month ago (I mentioned that to avoid the first 3 replies to this thread )
Is there a thermo switch that can be bad? Fan motors bad?
I have went all over the engine compartment and can't find any bad spots in wires or broken connections.
On a side note, my horn quit working yesterday too. I'm sure it's not related, just weird. The car is in great mechanical shape otherwise. I need to get this thing going, my truck is sucking down the gas while my work car is sitting, hehe.
Any help is greatly appreciated.
Old Aug 25, 2011 | 09:01 PM
TraviSS's Avatar
Fixed it today. One of the ground wires was bad behind the driver headlight. Apparently the horns and fans are grounded together there.
Old Apr 11, 2012 | 06:39 AM
michaelm's Avatar
I am at the end of my rope cooling fans not coming on their own they work i ave replaced evey thing i can imagine except the computor any one have secret to fix my problem
Old Apr 11, 2012 | 06:40 AM
michaelm's Avatar
2002 monte carlo ss dale earnhardt is my car sorry
Old Apr 13, 2012 | 07:22 AM
aussiek2000's Avatar
When it comes to electronics, you actually have to get your hands dirty and do some testing, it's not a matter of some guy on the internet telling you whats wrong. The first thing you need to do is see if the fans even work. Put 12v power to the plug on the fan itself.
Old May 1, 2012 | 05:15 PM
new01montess's Avatar
WHen i bought my 01 SS both cooling fans were junk. You need to use a simple test light and be sure there is power at the fans. Or get an extra fan plug and apply power directly to them to seeif they work. I got the new assembly online for $88 shipped. It was 150 plus tax at parts store.
Old Feb 4, 2019 | 01:21 PM
admjr53's Avatar
ran into the same on my 03 ss (3.8) a/c fan works but not the drivers side fan, also the horn stopped working, where did you find the ground wire??
Old Feb 4, 2019 | 01:50 PM
admjr53's Avatar
found it, horn works, going for a ride to see if the fan works now.
Old Aug 14, 2022 | 06:39 PM
chitwnhick's Avatar
You sir, are a godsend. Had the exact same issue, horn and all. Jiggled the only ground wire by the drivers headlight and sure enough, popped from the connector. Quick little soldering and good as new.
Old Sep 22, 2024 | 10:26 AM
John Wascavage's Avatar
Question
I'm having a similar problem. The fans just stopped working. Where is this common ground wire located?
