02 sensor
Old Jun 23, 2007 | 06:17 PM
bjammin's Avatar
Default 02 sensor
on my '01 monte, it kicked out a sensor code for "#1 bank, #2 sensor" does anyone know where I could find it? I found one on the top of the motor, but it's nothing like the part I got to replace it. It's a 3.4 motor. Any help would be appreciated.
Old Jun 23, 2007 | 07:03 PM
wiz kidd's Avatar
Default RE: 02 sensor
#2 sensor would be the one after the cat convertor wouldn't it?? i would think so anyway...not 100% sure on that though,
i would think that if its the one after the convertor and its single exhaust right there its going to say #1 bank, sounds like its the post cat convertor o2 sensor
Old Jun 23, 2007 | 09:41 PM
2000LS's Avatar
wiz, although seeming quite uncertain of himself, is correct on all accounts.
Old Jun 23, 2007 | 11:51 PM
wiz kidd's Avatar
so then its the one between the cat convertor and the resonator in that blasted u-bend!!
Old Jun 24, 2007 | 05:08 PM
04 Intimidator's Avatar
Welcome to MCF Ben!! You might just need to pull the OS2 Sensor out from the ubend and clean it. Hopefully that is all it is. It could also be a problem with the cat converter and if you have less than 100,000 miles on the car you can get it replaced for free I beleive under warrante.
98Z34
Aug 7, 2011 01:24 PM
FLMONTESS01
Sep 11, 2010 11:47 AM
Endo
Aug 26, 2010 10:16 AM
The Rev
Oct 19, 2008 09:08 PM
rcohen
Feb 12, 2007 08:49 PM
