02 Monte SS ?
Old Oct 29, 2007 | 10:40 PM
Blownville's Avatar
Default 02 Monte SS ?
I hope this is in the right section. I am new here and signed up to help my dad out. He has a 2002 Monte SS with about 50k on it and he is having troubles. Almost everytime he starts the car the overhead display, AC button, Recirc button, and the blower fan do not work. Sometimes it takes a min, and sometimes he said he can drive for about a mile before everything starts working again. Once in a while everything works like normal from the start. Could this be a relay? All the fuses have been pulled and checked for connection. Thanks.
Old Oct 29, 2007 | 11:09 PM
kweef's Avatar
Default RE: 02 Monte SS ?
welcome to the site! sounds like ur having some issues and there r plenty of ppl here to help u out, good luck!
Old Nov 1, 2007 | 09:14 PM
RocknSS04's Avatar
If it is doing it at start up, sometimes, and the headlights, trip computer, etc flicker, it's the body control module. EVERYTHING in these cars are controlled by it. When you turn on your lights, the switch tells the computer to turn on the lights! I had to replace mine in my '01 SS LE. Pretty sure I'm right on this.
Wayne
http://www.cardomain.com/ride/2319272
Old Nov 7, 2007 | 09:20 PM
Blownville's Avatar
Ok cool, do you have any clue where it is located? Thanks.
Old Nov 7, 2007 | 10:09 PM
kingreyna's Avatar
I've been having that problem for a coupleof years on my 02 LS. I'm also sure its the BCM. I just decided to live with it. Doesn't happen that often now.
Heck, when mine does that the ac compressor will also turn on (even though no air is coming out) and the cruise control will stay on or flicker on/off.
Old Nov 11, 2007 | 03:14 PM
04 Intimidator's Avatar
It is located roughly behind the emergecy brake. You can pick them up at junkyards and ebay.
Old Nov 11, 2007 | 03:52 PM
RocknSS04's Avatar
It's under the carpet under the drivers seat.
Old Nov 12, 2007 | 07:13 AM
Blownville's Avatar
Cool thanks for the info.
