02 Monte Carlo ss problems
Old Mar 24, 2013 | 10:29 PM
02 monte ss's Avatar
Default 02 Monte Carlo ss problems
Hey thought I could get on here for some help lol I have a 02 Monte Carlo ss and here recently my A/C hasn't been working it will cut on sometimes but no matter what level u put it on it wint work but some other issues that happen when the air goes out is my cruse control won't work and my little Thjng that shows the temp outside is blank it's been going on for about 3 months now oh and sometimes if the air is working the cruse will flash and it will just stop my car has a mind of its own lol any ideas would help thanks
Old Mar 25, 2013 | 09:25 AM
Monroe's Avatar
Monte of the Month -- December 2013
Had a similar issue with mine, have you tried replacing the fuses?
Old Mar 27, 2013 | 05:49 PM
I don't think it would b that cus if the fuse is blown wouldn't it not work at all ??? It works when it wants to....
Old Mar 27, 2013 | 09:38 PM
TruTechGeek's Avatar
i read in another thread on here that those are symptoms of a bad ignition switch. i too have that same problem
Old Mar 28, 2013 | 12:26 PM
Ignition switch ?? How could it be that ... My car starts fine everytime lol I would think it's like a wiring problem since like 3 things mess up all at once ... But idk I'm clueless to cars... But I try to learn ... When one works they all work but if one don't work they all don't A/C , cruse control , and the little this that shows the temp outside ... It works when it wants to ...
Old Mar 28, 2013 | 03:05 PM
here is a link to another thread that discuss the same problems:
02 Monte Carlo SS electrical problems
im still looking for the one on this forum...
Old Mar 28, 2013 | 03:10 PM
After quite a bit of searching... here is the thread where a member here states the ignition switch was the solution to the problems you are having:
https://montecarloforum.com/forum/ge...ght-dic-35078/
Old Mar 28, 2013 | 10:03 PM
Justin's Avatar
ignition switch it is, when your having these problems is your little gauge on the roof not working as well? cause that's what my car was doing. the blower wouldn't turn on and the cruise wouldn't work and the gauge on the roof wouldn't work as well. I did a lot of research and changed out the ignition switch and haven't had a problem since, and its been well over a year now.
Old Mar 29, 2013 | 03:00 AM
Thank u so much !!! I'm going to look n on how much everything is going to run me thank u again cus everything u said a/c cruise and temp gage wasnt working
Old Mar 29, 2013 | 08:09 AM
Justin's Avatar
if you do it yourself under 100 bucks, if you have a shop do it around 300
