Turn Signal issues
Hello. im having a major problem with my turn signals. When i turn the signal eather right or left ,the lights dont flash consitantly. it flashes twice instead of once. every 2 or 3 flashes it flashes twice real fast. also while its doing that the voltage gage moves to the flash. i think it might be the 12V flasher but i cant find one..lol.
any suggestions..:eek: |
RE: Turn Signal issues
I dont know what the problem is but our 93 caprice wagon does that. Its so annoying.
Have you tried to change the flasher?If not I would start there.
You can also check all of your bulbs and make sure none are burned out.
well my middle brake light in the back is out. would that affect that in any way.
well i changed the back break bulb and one of the flashers. apparently the hazard lights operate on a seperate flasher. i changed the flasher for the turn signals and still the same problem. Im really confused now..lol.
you can put in a heavy duty flasher not the bulb but the flasher. should be next to or in the same area as the fuse pannel. looks like a alum. can but smaller.
Some were on the fuse pannels and were around plastic part at the bottom in the fuse pannel. other thne this i have no clue i havent heard of this happenign for a incondesent bulb LED lights sure but not the old versions. |
"you can put in a heavy duty flasher not the bulb but the flasher. should be next to or in the same area as the fuse pannel. looks like a alum. can but smaller.
Thanks you mickey I did just that and it seemed to solve the problem. Thank you all its so nice to not have to worrie about if your turns signals are working ..lol |
glad it helped.
you used to see this alot in old pickups with a two kit wired in to them also. or they would flash real slow. |
