whats size bulbs does a 1998 monty use in the dash cluster
Old Sep 26, 2010 | 05:16 PM
ohmonty26's Avatar
Default whats size bulbs does a 1998 monty use in the dash cluster
whats size bulbs does a 1998 montyz34 use in the dash cluster
i wanna upgrade them to leds and how do i get the cluster out i took the dash trim off do i take thoes little bolts off or what
Old Sep 26, 2010 | 05:56 PM
mrl390's Avatar
They take 194 bulbs. You will need 5. Remove the trim bezel from around the gauges by popping it off. Then take the screws out at each side of the gauges that hold it in. Once the cluster is out, you need to remove the grey twist out sockets. The 5 big ones are the ones you need to replace. Once the sockets are out, remove the bulbs from them and put in the LEDs and then put everything back together.
Old Sep 26, 2010 | 07:56 PM
ohmonty26's Avatar
Default hey
what about the bulbs for the hvac what size are thoes
Old Sep 26, 2010 | 09:14 PM
mrl390's Avatar
I dont know about those. I havent had them out.
Knightwolf702
Jun 5, 2014 03:36 PM
ohmonty26
Sep 30, 2010 09:08 AM
SSOOCH
Dec 8, 2008 10:45 AM
couch
Mar 19, 2008 04:14 PM
InTheIROC
Feb 7, 2007 11:47 PM
