what kind of system is in YOUR monte? :D
Old Sep 22, 2009 | 01:48 AM
  #51
My monte's setup before it got broken into:
-Pioneer Premier 730 head unit
-2 6.5" Massive coax's (w/ external crossovers) in kickpods
-4 6.5" Massive coax's (ext crossovers), 2 in each door in fiberglass panels
-2 6.5" Massive coax's (ext crossovers) in the rear deck pointed towards the cabin
-Earthquake 2200.4 4 channel
-Earthquake D3 mono sub amp
-2 Atomic ELE 12" subs
-Audiocontrol Line driver
-2 Polk Db 6.5"s in trunk panel, turned on/off w/ trunk light (never completed)
I had recently sold the custom fiberglass kickpods with the intent to put those speakers into the trunk- but since the theft, all I have left are the speakers and line driver. Still not sure where I'm going to go from here.
Old Sep 23, 2009 | 12:12 PM
  #52
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Talking MY stereo!!
http://www.carstereo.com/thumpingetocar06
Click on the link... it will be worth your time.
The last install with the MTX 9500 hit 156 DB's this past summer and now is currently under construction with a bigger, badder setup!
Old Sep 25, 2009 | 09:04 AM
  #53
04MonteLS's Avatar
Old Sep 25, 2009 | 10:15 PM
  #54
RocknSS04's Avatar
Custom CNC'd guage cluster with Stewart Warner 1 1/2" voltmeter and transmission temp' gauges, blue lit.
Pioneer Premier DEH8800 6 channel head unit
JL Audio 300/4v2 and 1000/1v2 amps
JL Audio tweeters in the "A" pillars
JL Audio 6 1/2" component door speakers
JL Audio 6 x 9" 3 way rear speakers
JL Audio 12W6's (2) 12" sub-woofer in a custom box
400 watt power inverter
110v outlet in the console and the trunk
12v outlet in the trunk
Passport 8500 Radar detector hard-wired
Optima red top battery
Optima yellow top battery in the trunk
Monster cables and connections.
Remote mount factory radio.
Pioneer XM tuner
Sirius tuner
110v, 300watt power inverter replacing the factory amp
110v outlet in the electrical panel
12v outlet, same place
RCA input jacks, same place
1/8" aluminum framework to hold it all in place
1/4 hardboard with padded black vinyl electrical panel cover
Dyna_Mat sound deadener in the trunk
Onstar moved to under the window tray
Old Sep 26, 2009 | 08:57 AM
  #55
The Popcorn King's Avatar
Wayne. I love your set up man. I wish i could set as crazy as i want to, but since mine is my daily driver/grocery getter, I need my trunk space.
Old Sep 26, 2009 | 09:33 AM
  #56
Enzo354's Avatar
STILL SLOW
Ive always kind of wondered this, but how do you charged the yellow top in the trunk. You you have it wired to the alternator?
Old Sep 26, 2009 | 10:08 AM
  #57
Photobucket
Wink
"Ive always kind of wondered this, but how do you charged the yellow top in the trunk. You you have it wired to the alternator?"
I also have a multiple battery setup and I have mine wired in series with one another, use 0 gauge cable and make sure you have a great ground for the battery it self. Well worth the time and work, no light dimming, and if you can......put a capacitor somewhere in there! Hope this helps!
Old Sep 26, 2009 | 12:54 PM
  #58
my stuff will be up soon, i just got it done yesterday
Old Sep 26, 2009 | 02:44 PM
  #59
Justin's Avatar
Originally Posted by 01-ON-AIR
premier 860 mp deck
pioneeer avic-n5
pioneer back up camera
premier 520's 5 1/4 componets
premier 720's 6 1/2 componets
(x2) mtx audio thunder 8500's-12"
(x2) mtx blue thunder pro 500xd -sub amps
(x2) mtx blue thunder pro 150x2 -6 1/2's amps
(x2 mtx ble thunder pro 50x2- 5 1/4's amps
mtx audio lsx2 crossover
jbl gt422 eq
(x2) 5" visor monitors
13" monitor trunk lid
(x2) kinetik audio hc 800
all streetwires, wires,rca's, and blocks
ohio generator 180 amp alt.
is that your car in the pic???
Old Sep 26, 2009 | 09:00 PM
  #60
01-ON-AIR's Avatar
yep, check out my photo album.
