vss wire location
Old Nov 15, 2006 | 01:10 AM
whitedi's Avatar
Default vss wire location
hey guys i have a 2000 monte ss and i'm trying to locate the vss wire. do any of you guys have a clue to were it is located
Old Nov 15, 2006 | 07:35 AM
04 Intimidator's Avatar
Default RE: vss wire location
I beleive the VSS wire is dark green in the gray 16 pin plug in the BCM. It should be located above the kick plate on the driver side... roughly directly behind the parking break against the firewall.
Old Mar 7, 2008 | 07:23 PM
mickey's Avatar
ok i have been told that it is also int eh plugs behind the radio that hook in to the factory harness for the radio.
DARK green/white
Can any one say yes for sure on this?
Old Mar 8, 2008 | 09:47 AM
bowtietech's Avatar
04 Intimidator is correct. The VSS signal wire can be found in the gray,16 terminalBCM connector C3 /terminal B5(dark green wire). It can also be found underhood at the cruise control module connector terminal "K", also a dark green wire. All other modules that need vehicle speed input(radio,driver information center,speedometer,etc.)receive the signal through the Class 2 communication circuit.
Below is a diagram of BCM connector C3..........
Murray137
Oct 20, 2012 08:13 PM
Wilco
Apr 27, 2011 01:07 AM
wht02monte
13
Apr 2, 2010 01:50 PM
chaleyss
Mar 7, 2010 09:16 PM
whitedi
Nov 15, 2006 02:08 PM
