vss wire location
I beleive the VSS wire is dark green in the gray 16 pin plug in the BCM. It should be located above the kick plate on the driver side... roughly directly behind the parking break against the firewall.
04 Intimidator is correct. The VSS signal wire can be found in the gray,16 terminalBCM connector C3 /terminal B5(dark green wire). It can also be found underhood at the cruise control module connector terminal "K", also a dark green wire. All other modules that need vehicle speed input(radio,driver information center,speedometer,etc.)receive the signal through the Class 2 communication circuit.
Below is a diagram of BCM connector C3..........
