6th Gen ('00-'05): is there a wire for shifter in "Park"?
Old Oct 28, 2016 | 09:53 PM
darkmage1991's Avatar
Default is there a wire for shifter in "Park"?
no need
Old Oct 31, 2016 | 07:18 PM
ok so
Old Nov 2, 2016 | 09:13 AM
Gonna bump this. Anyone have any ideas? If no answer soon I fear I will need to get a switch of some sort to wire into the center console shfter area
Old Nov 2, 2016 | 12:39 PM
user 35764368's Avatar
I know there is a cable that runs from the shifter to the ignition switch. I don't believe its electrical in nature??
Old Nov 2, 2016 | 01:02 PM
Yea I seen that but it looks to be what locks the ignition and prevents the key from coming out when it's not in park.
Old Nov 6, 2016 | 11:27 AM
Well I got it working...mostly
I got on alldata and looked at pretty much every single electrical connector on the car. I did find that p and c signal wires from the transmission looked like they might work. And well the c signal wire worked perfectly all except it also sends a ground signal when the shifter is in 1st... So there is that issue but it small and I can live with it since I will never have a reason to leave the car in 1st.
For future reference for anyone else that wants to know. Here is a pic from all data on the connector to use and what the wire colors are.
