is there a wire for shifter in "Park"?
no need
ok so
Gonna bump this. Anyone have any ideas? If no answer soon I fear I will need to get a switch of some sort to wire into the center console shfter area
I know there is a cable that runs from the shifter to the ignition switch. I don't believe its electrical in nature??
Originally Posted by sharpeezss
(Post 696974)
Well I got it working...mostly
I got on alldata and looked at pretty much every single electrical connector on the car. I did find that p and c signal wires from the transmission looked like they might work. And well the c signal wire worked perfectly all except it also sends a ground signal when the shifter is in 1st... So there is that issue but it small and I can live with it since I will never have a reason to leave the car in 1st. For future reference for anyone else that wants to know. Here is a pic from all data on the connector to use and what the wire colors are. http://i66.tinypic.com/zvwg0y.png |
