Swaping CD Player??
Old May 15, 2007 | 10:46 PM
Jiggly's Avatar
Default Swaping CD Player??
[&:]Monte Carlo SS 2002, ok i no that u need the stock cd player to reset your oil n other allerts that come through the message center i was wondering if you can hook up a sub system to the orignal CD player in there.. if not n u take it out arent u kinda screwed w.o tha ability 2 reset your allerts through the messanger...[&:]
thx, Jiggly
Old May 16, 2007 | 05:16 PM
drgonzo3705's Avatar
Default RE: Swaping CD Player??
read the owners manual and it will tell how to reset them without the factory deck. and yes you can hook up subs with the factory deck . its just a matter of preference i had mine hooked up like that but wanted better SQ so what are you wanting to do?
Old May 16, 2007 | 10:55 PM
FlynhghR's Avatar
I had an 03 LS with the factory amp. Best buy hooked up a sub for like 130 bucks with a Line output converter. Quality was pretty good, but it did require a modification to the stock wiring harness. I had no complaints, worked fine for ages. My new 06 3LT has a very similar Line output converter, except it plugs in line with the stock radio, meaning no cutting wires. You can pick them up at http://www.pac-audio.com/oem1kits/listallaoem.asp Use The Better Source. I ordered it from them, was a simple plug and play. Living here in Iowa their Chicago location got it to me in like two days. http://www.thebettersource.com/
I should note, that with mine the wire they provide for the 'Remote' wire source for the amp didn't work right. It had power all the time, which would leave your amp powered up constantly, draining the battery quick. I ended up just taking signal from the ignition.
Old May 18, 2007 | 04:11 PM
Jiggly's Avatar
i dont know what i want to do yet but the dealership forgot 2 rest my oil allert because they did an iol change when i bought it.. n i had 2 rest it n i was like damn im going to have to keep the stock deck to reset the allerts.. thx soo muthc thats all i wanted to know n i may get like 2-4 10'? depends on how muthc i save up ill get back to you guys on it and ill send a pix of it,,
thx again,
Jiggly
Old May 24, 2007 | 11:31 AM
Monte_04's Avatar
You can hook up a system to your stock its what i did for now. all you need to get is a high to low converter and it will have RCA outs on it and just wire it up to your rear speakers. ill get the name of the converter if you need it, i just dont have the name right now, let me know if u need more info.
Herlsy
Apr 1, 2011 11:11 AM
killerbee615
Aug 11, 2010 07:56 AM
colin
Apr 24, 2009 11:13 PM
04MonteLS
Oct 10, 2005 12:40 PM
big green dog
20
May 31, 2005 04:44 PM
