stock stereo ????
Old Oct 14, 2007 | 01:15 PM
thesheriff50's Avatar
Default stock stereo ????
hi my name is chris i just purchased a 06 lt and it has the single cd system id like to upgrade and put the 6 disk unit in . I would be thankful for some info . also id like to say i like your site here . also is there any way to add the sterring wheel controls to the wheel if they arnt there already??
[IMG]local://upfiles/3233/224766B999CA490B94D4F392000DBA0E.jpg[/IMG]
Old Oct 14, 2007 | 02:11 PM
kweef's Avatar
Default RE: stock stereo ????
welcome to the site chris! and im not sure you can add steering wheel controls without replacing the entire thing
Old Oct 14, 2007 | 06:54 PM
[sm=welcomesign.gif]
Welcome Chris. Congrats on your purchase.
I know you said you're going with the factory 6 CD system.Definitely a better choice.
I think you should know before your purchase a new stereo, the audible warnings/chimes and OnStar use the factory sound system. So if you decide to go with an aftermarket system, you'll most likely lose your chimes and such.
I think you'd have to replace the wheel also. Check the junk yards and the internet, who knows, you may get lucky and find a steering wheel with controls off of a wrecked '06 or '07. They'd be rare, and you'd most likely have to transplant the airbag from yours, but it'd be cheaper than the dealer.
Old Oct 14, 2007 | 07:39 PM
04 Intimidator's Avatar
I beleive you have to replace the whole dash wiring harness to get steering wheel controls. I don't think it is a seperate harness or it doesn't seem that way when you look at it.
Old Oct 14, 2007 | 11:36 PM
what id like to know is can the stock 6 disk be transsplanted were the single was ? i dont have on star so no issue there[8D]
Old Oct 18, 2007 | 10:34 AM
any thoughts on if the plug will work????
Old Oct 18, 2007 | 11:02 AM
vita's Avatar
hey, well, with the stock harness, I think it would if its a GM issued deck for our cars. I got my car used, so I couldnt chose what options are on it. If your going with a different deck (clarion, pioneer, ect) then, you will need the correct harness. if anything, go talk to a car audio shop by you, they should be able to tell you right away if itll work with your stock harness or not.
Old Oct 18, 2007 | 06:27 PM
If your putting in the 6 disk factory stereo in place of the single disk factory stereo, the connector should fit without a problem providing you're putting in stereo from the same generation GM vehicle.
Joe Bloggs
Dec 5, 2010 04:58 PM
drjesus616
Jul 31, 2010 07:48 PM
silver1
Jan 30, 2009 10:25 PM
thewhitestcarlouknow
Dec 24, 2008 06:16 PM
02CarloLS
Jul 5, 2008 03:42 AM
