stock stereo ????
hi my name is chris i just purchased a 06 lt and it has the single cd system id like to upgrade and put the 6 disk unit in . I would be thankful for some info . also id like to say i like your site here . also is there any way to add the sterring wheel controls to the wheel if they arnt there already??
[IMG]local://upfiles/3233/224766B999CA490B94D4F392000DBA0E.jpg[/IMG]
[sm=welcomesign.gif]
Welcome Chris. Congrats on your purchase.
I know you said you're going with the factory 6 CD system.Definitely a better choice.
I think you should know before your purchase a new stereo, the audible warnings/chimes and OnStar use the factory sound system. So if you decide to go with an aftermarket system, you'll most likely lose your chimes and such.
I think you'd have to replace the wheel also. Check the junk yards and the internet, who knows, you may get lucky and find a steering wheel with controls off of a wrecked '06 or '07. They'd be rare, and you'd most likely have to transplant the airbag from yours, but it'd be cheaper than the dealer.
hey, well, with the stock harness, I think it would if its a GM issued deck for our cars. I got my car used, so I couldnt chose what options are on it. If your going with a different deck (clarion, pioneer, ect) then, you will need the correct harness. if anything, go talk to a car audio shop by you, they should be able to tell you right away if itll work with your stock harness or not.
If your putting in the 6 disk factory stereo in place of the single disk factory stereo, the connector should fit without a problem providing you're putting in stereo from the same generation GM vehicle.
drjesus616
Jul 31, 2010 07:48 PM
thewhitestcarlouknow
Dec 24, 2008 06:16 PM
