steerin wheel controls
Old Feb 11, 2008 | 10:56 PM
98monte's Avatar
Default steerin wheel controls
will the steerin wheel controls still work if i hook up a new radio to the car. will it get power to them to change the song and raise the volume. or not.. i heard it wouldnt but wanted everyones second oprion.
Old Feb 12, 2008 | 12:09 AM
Farfig's Avatar
Default RE: steerin wheel controls
You lose the controls, but you can gain them back by installing something else.
One of the other guys can give you a link to find that something else, but for the life of me I can't think of the name
Old Feb 12, 2008 | 07:35 AM
98monte's Avatar
can i remove the buttons on the steerin wheel after installin a new radio so that they wont be unuseful and tacky lookin.
Old Feb 12, 2008 | 11:35 AM
scc24540's Avatar
z34phoenix is the one that did it. he pulled his controls out and stuffed a ipod type player into them. but like i told u ant just get some plastic the same color as ur wheel, cut to shape and stick it in and there u go
Old Feb 12, 2008 | 04:41 PM
bigboi's Avatar
little off topic but, Where can i get a steering wheel with controls, and will they work with the stock head unit i have now?
Old Feb 12, 2008 | 06:00 PM
z34phoenix's Avatar
to add steering wheel controls to a car that didnt have them, you need:
-the wheel w/ controls
-a new turnsignal switch harness... the controls follow thru this harness thru the steering columb
- the rest of the harness to the stock headunit.
the adapter for the controls to use on an aftermarket HU are called (PAC - X ) you can find them at audio places or online. basicly they turn your controls into a universal remote control but copying the controls from your new headunits own remote.... so your new headunit has to have a remote for this adapter to work.
Old Feb 12, 2008 | 09:31 PM
04 Intimidator's Avatar
ORIGINAL: 98monte
Since you already have the steering wheel controls, you just need to pick up a PAX adapter and hook it up... If I remember it only has 5 wires.
Old Feb 13, 2008 | 07:39 AM
98monte's Avatar
where can i get the pax wire? and does it hook into the back of the new radio?
Old Feb 13, 2008 | 10:00 AM
bonang's Avatar
This PAX unit is not just a wire. It is a box that mounts under your dash and it acts like the remote from your CD player. I few things you have to consider is this. The aftermarket deck that you are going to install has to have a remote. The remote is for programming the PAX unit. Think of the Wheel controlls as your new remote. Now you can order the unit here:
http://www.crutchfield.com/App/Produ...00&tp=3405
This also will come with a details install guide and free tech support if you require it.
Here is a little write up on it:
You want to install a non-factory replacement radio in your vehicle, but you hate to give up the convenience of your factory steering wheel radio controls. No worries! PAC's SWI-X interface allows you to use the steering wheel controls in a wide variety of vehicles to command any aftermarket radio with wireless remote capability.
Installation is straightforward — just connect a few wires (a 3-wire hook up in many cars). Programming is made easy with step-by-step LED confirmation. Once connected, the SWI-X's failsafe memory will learn up to 12 functions from your receiver's wireless remote, retaining them even if battery power is interrupted. Dimensions: 3-3/4"W x 1-1/16"H x 1-9/16"D. 1-year warranty.
Also check this out.
https://montecarloforum.com/m_71980/tm.htm
Old Feb 13, 2008 | 11:45 AM
Bahh.. That is what I meant: PAC's SWI-X.
Had a Homer moment.
