7th Gen ('06-'07): Speakers with Factor head unit and sub
i found this:
http://www.installer.com/item/displa...p?it=aoem-gm24
and here is a crossover / low pass filter that sorts out the bottom end for sub amps
http://www.installer.com/main.php?page=hilo
not trying to be a smart ***
I had Hertzs speakers installed and RockfordFosgate amp
http://www.rockfordfosgate.com/produ...tails/t400x4ad
Audison bit Ten Processor
Audison bit - bit Ten
i found this:
Add an Aftermarket Amplifier harness for General Motors vehicles AOEM-GM24 PAC
Not sure if that adapter is the right one for the Monte Carlo setup. There is no adapter available to plug into the (3) factory amp connectors. You'll need to cut and splice...all of the wires are right there at the amp. You'll retain all of the factory functions as you're simply replacing the amp in the rear, which does not produce the tones, only amplifies them. You don't need to remove the radio to replace speakers or add amplifiers.
Actually...
My system has AMPs that push over 4,500 Watts...
However.. we loose about 500 watts due to voltage ... IE; Battery/Alternator...
But the constant is 4000 watts... Since there in line with one another they have been Split ... 1 push's the subs... and the other powers the other 6 speakers!
I'm fortunate unlike some others...
This system has been in the car since I purchased it new in 1999.
15 yrs later:
It still sounds crystal clear and if you crank up the subs (I have a separate **** to turn them up and down) It will definitely not only vibrate your Brain! But your hair will feel as though theres a wind storm going on....LMAO..
I have maybe turned it up to do that maybe 2 or 3 times over the years..
I like it the way it is and plan to keep it all intact.
15 yrs later:
Lol that amp isn't anywhere close to 4k watts.. the "4200" comes from being 4channels @ 200watts
6th Gen ('00-'05): Swapping OEM head unit for another OEM unit...???
Habbibie
Jun 27, 2013 01:09 PM
Mxblaster292
Apr 1, 2013 11:31 AM
Deadsnake
60
Feb 10, 2010 10:56 PM
CHOWEE21
Jun 26, 2006 10:12 AM
