Speaker wiring colors
Here is the standard info.
Rear Speakers
6" x 9"Rear Deck
Left Rear (+)
Brown
Left Rear (-)
Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
There isn't too much available online for the premium stereo, you might be able to find out specifically in a Haynes manual.
Rear Speakers
6" x 9"Rear Deck
Left Rear (+)
Brown
Left Rear (-)
Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
If i may reply to this post, Their are like 4 shades of blue wires in the rear harness connected to the factory amp, so it's kinds of hard to figure out which 2 lead to the rear speaker. I would like to know exactly which 2 of the 4 they are because my amps dead, and I want to cut the wires from the harness to the speakers directly
This may be useless for you. Here is the information for an '06.
2006 Chevrolet Monte Carlo Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Violet/White
Car Stereo Dimmer Wire: Purple/White
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Left Subwoofer Speaker Positive Wire (+): Dark Blue/White (at amplifier)
Left Subwoofer Speaker Negative Wire (-): Light Green/Black (at amplifier)
Right Subwoofer Speaker Positive Wire (+): Dark Green (at amplifier)
Right Subwoofer Speaker Negative Wire (-): Light Blue/Black (at amplifier)
Copied from modifiedlife.com
6th Gen ('00-'05): Factory speaker wire colors +/-???
sethrotull99
Aug 23, 2021 12:00 AM
NYGiantsfan
Sep 6, 2009 04:19 PM
mtwallet
Jun 11, 2007 10:53 PM
