sound system question about amplifiers PLEASE HELP THANKS IN ADVANCE
Old Mar 3, 2011 | 10:59 AM
blackmonte781's Avatar
Default sound system question about amplifiers PLEASE HELP THANKS IN ADVANCE
well i wanna install my zxkicker1000.1 mono block amp that has a 100A fuse ratting and possibly a alpine amp for the speakers that has a fuse rating of 50A. my alternator is 125Amps lol. is this even gonna be possible without destroying my alternator?
the kicker amp will power my 2 L5s and the alpine would power 4 polk speakers...should sound sick but is this even going to be possible? lol please help
Old Mar 3, 2011 | 11:30 AM
walkingonabullet's Avatar
thats just what the alt produces, the battery can easily take 400 amps of draw, the problem is the battery keeping up, a stock battery how ever will easily keep up with 150 amps, your barley over your rating, plus those are the max ratings, that 100 amp mono block will pull 50-65 amps, and that 50 amp will pull 30 amps, so you're plennnnnnnty good my friend.
Old Mar 3, 2011 | 11:57 AM
hey thanks for the info! i upgraded my batter actually its a 720 CCA batter by interstate. im conserned about the lights dimming, should i use a cap with both amps?
Old Mar 4, 2011 | 03:58 AM
milrlyt's Avatar
720 cca and it's still dimming?
Old Mar 4, 2011 | 06:50 AM
no i have nothing hooked up yet my concern is when i do lol
Old Mar 4, 2011 | 08:12 AM
720 should be plenty, i have a 900 cca bat and its amazing, the stock battery was like 450sh i think.
Old Mar 4, 2011 | 11:28 AM
yea hopefully i wont get too much dimming of else ill have to spend even more money and get a good cap
Old Mar 4, 2011 | 02:02 PM
Milhouse's Avatar
I doubt your gonna have any dimming, especially if you replace the battery under the hood and upgrade the big 3, run the largest power wire ur amp can handle and make sure its all grounded nicely
Old Mar 5, 2011 | 03:12 AM
norwex's Avatar
I have a t1000.1 rockford fosgate power series pushing 2 10" kicker L7s with factory amp pushing infinity kappy 6x9s and components. I use 0/1 gauge wire kit and a 2 farad cap. I think its time to upgrade somewhere because my lights dim when the heavy notes hit. I can literally see my battery gauge drop. Im thinking of getting a power cap or a battery in the trunk? but yea to answer your question, you can do it but for that much juice you will need some extra reserve
Old Mar 5, 2011 | 09:15 AM
Milhouse's Avatar
Those T series Fosgate amps are known power hogs so even though you're only running 1k watts, I believe it! I've seen what happens in my buddies car when he put in a t1500, not good. But yeah, if you didn't upgrade the Big 3, your 0ga wire kit is all for show cause the most current it'll carry is based on the smallest wire in your power/ground wire setup. So if the battery is grounded to the chassis and/or engine block with anything smaller than 0ga (rest assured it is) then your 0ga is only carrying the current capacity of the smallest wire. I say do the Big 3 before you do anything else.
