running wire
pop up the driver side moulding and driverside back moulding(if around 01) gettin the wire throung the fire wall is the hardest part. but if you pop out the little gromet next to th brake booster with the thick wire goin through it and put your wire through and the rest is common sence after that
Lift the passenger carpet and and remove the under cover of the dash on that side, and you'll find a passage to through the firewall. You'll probably have to cut into it, depending what gauge wire you're trying to install. I passed a 0 and a 4 gauge wires through it.
Yeah, it wasn't easy either, but it's doable. When the wire enters the engine bay it will be inside of a rubber boot coming out of the firewall. I simply snipped a tiny hole in the bottom of the boot and fed the wire through it. To get the wire into the trunk I ran it down the center of the car and once into the back seat area I removed the back seat completely and ran it along the drivers side and into the trunk. The hardest part of the process was getting the wire through that grommet.
its almost to easy after that. just route it back somewhere. i ran the power along the passenger side, just removed the plastic door sill thing that keeps the carpet on and folded back some of the carpet and ran it back.
also to get it into the trunk i found it easy to remove the base of the rear seat witch just pulls up and out. and then fished it under the carpet and into the trunk.
I second that!!!
