Removing Factory Amp? 6th Gen
Old Apr 28, 2012 | 04:53 PM
dezzyboi16's Avatar
Default Removing Factory Amp? 6th Gen
I tried searching on here without much luck.
2002 Ls with the factory amp which I want to remove. You guys with upgraded systems, are y'all removing the amps or keeping them? If so, what needs to be done to keep everything running correctly without the amp in there?
I think I'm looking right over the answer so checking for assurance.
Old Apr 28, 2012 | 05:13 PM
dezzyboi16's Avatar
I already have an aftermarket head unit with the scosche gm09sr/gm09srb interface
Old Apr 28, 2012 | 05:35 PM
bizparr's Avatar
Are you planning on replacing the speakers too? If not I wouldn't bother touching the amp as long as it works fine..
Old Apr 28, 2012 | 05:39 PM
dezzyboi16's Avatar
I'm redoing the whole system and car, yes the amp is in the way.
Old Apr 29, 2012 | 09:24 PM
dezzyboi16's Avatar
To be specific,
I'm asking, is there any need for the factory amp if I'm replacing everything with aftermarket gear?
Like is there any functions of the car that are tied into the factory amp that I will lose if I remove it?
Old Apr 29, 2012 | 10:12 PM
bizparr's Avatar
Nope, no extra functions for the amp. You can just unbolt and remove in that case. I know people buy them occasionally when theirs die.
Old Apr 30, 2012 | 04:19 AM
dezzyboi16's Avatar
That's what I plan to do, thanks.
So, I should just unplug and unbolt and I'll be fine? I see the trunk light Is tied into that plug, so I should maybe hide the plug somewhere in the rear deck as it is right?
Just double checking
Old Apr 30, 2012 | 04:51 AM
walkingonabullet's Avatar
i just unplugged and unclipped mine and it works fine for the past 3 years. i dont think i did much with the harness prolly just flipped it into the deck
Old Apr 30, 2012 | 06:40 AM
dezzyboi16's Avatar
Aahhhhhh music to my ears! Thanks man.
Just didn't want to unhook this thing and something stops working.
Time to get started
Old Apr 30, 2012 | 08:04 AM
Time to get started
if you do aftermarket amps with the headunit there won't even be a signal sent back anywhere near where the amp is.
have you worked on stereos before?
