7th Gen ('06-'07): Radio Harness Question
Old Aug 4, 2017 | 07:39 PM
Swtss's Avatar
Question Radio Harness Question
I have a 2006 MCSS and I need to replace the radio antenna harness that plugs into the factory radio itself. How do I remove the old one and replace it with the new one? Where can you find the radio harness anymore, dealership saids it's a discontinued item now....any and all help/info greatly appreciated...tks in advance.
Old Aug 5, 2017 | 07:42 AM
96z34man's Avatar
Probably this is going to be a junkyard item.
Old Aug 6, 2017 | 11:32 AM
Swtss's Avatar
96z34man, yes I agree. I found a 07 mcss that still has the radio in it in the junkyard...just not sure how to remove the antenna cable part that plugs into the radio itself just yet. I don't know if I have to remove the entire dash cover or what...tks for the reply.
Old Aug 9, 2017 | 10:55 PM
Swtss's Avatar
any help and/or info would be greatly appreciated....tia
Old Sep 12, 2017 | 07:30 PM
Swtss's Avatar
any info on how to remove the top dash panel to replace the stereo radio antenna cable, or how the antenna cable is routed from the roof? any and all info greatly appreciated...tia
Old Sep 18, 2017 | 10:30 AM
96z34man's Avatar
Good luck with that. There is a thread here on how to do it; unfortunately, it's useless to us because our A-pillar is different from the 00-05, and the guy who started the thread refuses to answer his PM's.
Old Sep 19, 2017 | 12:47 PM
Swtss's Avatar
Thank You for the reply, I have no problem removing the dash trim or the dash itself. I am more worried about the air bag and sensor underneath it, I don't want it to go off in my face. I just need to replace the section under the top dash panel to the radio itself, I can get the harness from the yard, but I don't want to waste their dash just in case I may need some of it from the yard car again later.
Old Sep 20, 2017 | 08:32 AM
96z34man's Avatar
Disconnect the battery and you are guaranteed not to have a deployment, unless you stick sharp objects into the inflator.
Old Sep 20, 2017 | 12:01 PM
Anytime you're worried about the airbag deploying on you, I'd disconnect the battery too. Good advice.
