New speakers = Door panel rattle / buzz / vibrating
Ive tried twice now to install foam pieces on the highest elevation of the speaker mount. "Where it protrudes closest to the plastic door panel. Im still getting the buzz. I cant where its comes from. I realize that my biggest problem is not knowing exactly where the source of the vibration is located. If only I knew where that was it would be much easier to correct the problem. Once again nothing is being over driven..
It's not just putting foam around your speakers. The door card has a certain resonant frequency which I'm assuming is what is making your door rattle and buzz. Fixing the plastic clips is one thing, but trust me, it's probably not going to take care of all your problems. Our doors are craptastic and have multiple locations that buzz.
Find and secure all of the loose wires in the door card for one, including the plastic buttons attached to them and the area around them where they attach to the door card. They are notorious for buzzing. Wrap them in closed cell foam or peel and stick Ensolite. I highly suggest applying a few squares of quality deadener (AlphaDamp or Raammat is good) to lower the resonant freq of the door card and the door itself.
Also check to make sure you don't have any loose debris at the bottom of the door that may cause it to rattle.
I would get new push pins for the door panel and your problem will probably be eliminated.
It generally will not if it's just a standard set of 5 3/4's either, unless he has a ridiculous front stage without anything in the rear to compliment it
+1 to this. That's the term I was looking for. I know when I took the door panel off to redo the front speakers, the push pins got a bit messed up and caused the rattling.
As much as I would love to believe that the push pins are going to solve everything I don't see it happening. I've taken a very thorough look at the panel and "craptastic" is the best way to describe it. It could be ANY part of the plastic/fiberglass seams that could be rattling. All of the ideas you have given me seem to be the only possible route on fixing the rattle. Have you done this yourself? Or did you never experience the rattle?
I appreciate the input guys, you've been very helpful. I will let you know how everything plays out.
Just for grins & giggles...
Check the leads that go from the cone to the terminals. A friend of mine had a rattle coming from his speaker at certain frequencies and it ended up being the cone vibrating against one of those leads. He moved the lead and the rattle went away. It's a long shot but might be worth looking at.
