Need help removing Stereo 2006 LT
I have a 2006 LT & I want to remove the stereo so I can hook up an amp. The cover that surrounds the stereo will not come off is there a trick? Also I believe the remote wire for amp & antenna is pink does anyone know if this is correct?
the faceplate will not come off & i dont want to force it & break it. Does anyone know how to get it off, seems like there are enough "stereo" people out there that would be able to help me...
this should work if you break it i would ask um first.
http://cgi.ebay.com/06-08-Buick-Luce...item518f53fd7d
Judging by the pic of the trim ring in that eBay link, it's just clips holding it in place. If you've got it loose at the bottom, then just work your way around to the top. Don't be afraid to use your man-hand with it, just use common sense on where to pull. Start at the bottom and work around till you feel the next clip and pop it loose, it takes some force to pop those clips out.
Montelicious
Aug 5, 2011 09:30 AM
jcobz28
Aug 17, 2007 08:25 PM
