Need help removing Stereo 2006 LT
Old Feb 17, 2010 | 04:38 PM
Theamazingsnyderman's Avatar
Default Need help removing Stereo 2006 LT
I have a 2006 LT & I want to remove the stereo so I can hook up an amp. The cover that surrounds the stereo will not come off is there a trick? Also I believe the remote wire for amp & antenna is pink does anyone know if this is correct?
Old Feb 21, 2010 | 05:44 PM
Default does anyone know how to take the faceplate off
the faceplate will not come off & i dont want to force it & break it. Does anyone know how to get it off, seems like there are enough "stereo" people out there that would be able to help me...
Old Feb 21, 2010 | 06:42 PM
mrl390's Avatar
Just be patient. Someone will be able to answer your question.
Old Feb 21, 2010 | 07:00 PM
mak330's Avatar
it is very easy just pop off the trim ring around the cd player with a panel popper or some piece of sturdy thin metal.
take your time and GL im sure you can buy the trim piece if you break it lol
Old Feb 21, 2010 | 07:03 PM
Thanks for the help, I can get under the plate at the bottom but it just will not pop off on the sides or top. Anyone know if the pink wire is the remote wire for amp?
Old Feb 21, 2010 | 07:45 PM
mak330's Avatar
im not sure. i know theres wiring diagrams out there. try to google it.
Old Feb 21, 2010 | 08:58 PM
mak330's Avatar
this should work if you break it i would ask um first.
http://cgi.ebay.com/06-08-Buick-Luce...item518f53fd7d
Old Feb 21, 2010 | 09:20 PM
Dbl_D718's Avatar
Judging by the pic of the trim ring in that eBay link, it's just clips holding it in place. If you've got it loose at the bottom, then just work your way around to the top. Don't be afraid to use your man-hand with it, just use common sense on where to pull. Start at the bottom and work around till you feel the next clip and pop it loose, it takes some force to pop those clips out.
Old Feb 22, 2010 | 05:19 PM
Thanks for the help everyone!
tps221
Feb 27, 2013 07:15 PM
Montelicious
Aug 5, 2011 09:30 AM
supercharged SS
Mar 28, 2011 02:32 PM
jcobz28
Aug 17, 2007 08:25 PM
