My traction control wont turn on
Old May 31, 2016 | 06:34 AM
nfenner86's Avatar
Default My traction control wont turn on
I have a 2000 monte carlo ss and im not sure why but when i turn on the car. The traction control light comes on saying it is off. But when i hit the button, nothing happens?
Old May 31, 2016 | 02:18 PM
Justin Knight's Avatar
You have what is most likely a bad wheel speed sensor (wheel bearing) or and trans output shaft speed sensor that has gone bad. No ABS light?
Old May 31, 2016 | 03:44 PM
Definitely check the wiring to each speed sensor (rears too)
Old Jun 1, 2016 | 07:53 AM
nfenner86's Avatar
The abs light isnt on. Its just the trac light
Old Jun 1, 2016 | 05:12 PM
Not a bad idea to spend the money and get the abs codes read with a scanner. Rarely is it anything but a bad bearing or wiring going to the bearing. But make sure you buy acdelco or timken replacement bearing if that's what the problem is. Those two are the best ones.
