my old lady's monte carlo
Old Jan 29, 2012 | 08:43 PM
genesisjoelton's Avatar
ok guys i have a wiring harness and her factory radio has 2 plugs and i understand the wireing part but this harness i bought from bestbuy was 100$ AND it has some door carm thing and i have tried 2 differnt harsness one from walmart and the one i have now and neither one i get sounds so tell me what can it be
Old Feb 3, 2012 | 06:20 PM
anyone
Old Feb 3, 2012 | 08:53 PM
walkingonabullet's Avatar
your chimes aren't working? what have you wired, what deck are hooking up, are you using afer market amps, are you using processing, what year is the car, what is the serial of the 2 harnesses you got, the one from best buy is RIGHT guarenteed. you only use one of the harnesses i believe, the other one was for the other car features but those are handled internaly with out a stock deck, you can manage the things it controled through your ignition switch and break pedel sequences.
Old Feb 6, 2012 | 11:10 PM
Ok everything is factory and the amp and all the harness Idk it has a box and alot of wires the car is a 01 Monte Carlo as and I can't find a pic of the harness I got but some one just tell me what's wrong everything comes on and works but no sound
Old Feb 6, 2012 | 11:15 PM
01 Monte SS's Avatar
does the stereo have output to an amp? if so make sure the rca/amp output is turned off so its sending signal through the speaker wires..
Aug 23, 2014 05:03 AM
Montecarloguy07
Sep 28, 2010 08:30 AM
RickCoMatic
Aug 29, 2008 03:35 PM
BeachBumMike
Aug 13, 2006 12:32 PM
