mrl390's Sound System PICS
Old Oct 19, 2009 | 09:19 PM
  #31
locknload's Avatar
For the rears you could set the rear crossover to full and then tune it just like Dbl said. just watch out on the bass, i would keep the bass boost to a min if you are going to run the crossover at full, you could also set the crossover to a lower Hz and just run it that way also.
Old Oct 24, 2009 | 09:53 PM
  #32
mrl390's Avatar
Well here is my progress so far. Ive got the headunit wiring all soldered up, I put in the amp and mount and ran all the speaker wire and RCAs as well as the remote turn on. I also have the rear speakers in. I still need to put the front speakers in, run the power and ground for the amp, pop the headunit in and tune the system, then put basically the entire interior back together. Here are some pics of the progress:
I have a wire loom I am going to cover the speaker wire with so they wont stick out.
I can just run the ground right to the strut tower and use one of the bolts. Its coming along and I got alot done today. Hopefully Ill finish tomorrow. More pics/vids to come.
Old Oct 24, 2009 | 10:02 PM
  #33
thats some nice looking custom work, is the rear speaker setup anything like the 04 rears?
Old Oct 24, 2009 | 10:16 PM
  #34
mrl390's Avatar
I believe both 5th and 6th gens use 6x9s in the rear.
  #35
Dbl_D718's Avatar
Lookin good. I like the amp rack too, looks cool
Old Oct 24, 2009 | 10:24 PM
  #36
mrl390's Avatar
Thanks, I made that myself out of some plywood and pieces of 1"x3/4" mahogony. Its pretty sturdy and you dont see the amp unless you bend down and look up in.
Old Oct 25, 2009 | 07:03 PM
  #37
mrl390's Avatar
Well I got everything buttoned up today. I ran the power and ground cables and installed the headunit, put the speakers back in and put the car all back together. I still need to tune the system but I had it on and playing music and everything works fine. I still need to take some pictures, I didnt get around to it today but I will try and get some either tomorrow or tuesday.
Old Oct 25, 2009 | 07:43 PM
  #38
The Popcorn King's Avatar
Very kewl man. Your going to have to get a sound clip.
Old Oct 25, 2009 | 07:54 PM
  #39
mrl390's Avatar
I will for sure once I get it tuned.
Old Oct 25, 2009 | 10:00 PM
  #40
they do but i donno about it being the same setup to get back there and stuff
