Major radio problem
Old Jan 11, 2010 | 07:43 PM
paintballerr78's Avatar
Default Major radio problem
Well i had an aftermarket radio got rid of it and bought a different one for less money. Well i go to put this one in and no power to it so i think bad wiring connection nope not it. I try by factory radio it lights up and everything but the main screen that says the time and stations all that stuff does not turn on. What could be causing this?
Old Jan 11, 2010 | 07:48 PM
mak330's Avatar
maybe a fuse, is you less expensive one new or used?
Old Jan 11, 2010 | 07:50 PM
its a new alpine....Idk what fuses to even begin with to check. Even if it was the new radio my old factory one should work. I just dont get it i took out the one i had and it worked perfectly fine now this happens
Old Jan 11, 2010 | 07:54 PM
mak330's Avatar
idk almost every aftermarket radio has a fuse of two in the back of it. if you installed the newest one with the battery connected it could have blown that fuse. hopefully its a 10 cent fix, either that or i would take it back were you bought it from. 5 percent of all electronics are faulty.
Old Jan 11, 2010 | 07:57 PM
Ya but what i dont understand is why the factory radio would not work
Old Jan 11, 2010 | 08:01 PM
mak330's Avatar
i dont understand the first post so you,
1 put in an expensive unit, worked fine, took it out
2 tried the factory radio, and it doesnt light up
but you want to put another headunit in but cant get any power to it nor the factory radio
Old Jan 11, 2010 | 08:03 PM
I had an aftermarket headunit jensen flipout i didnt need the screen so i sold it to a friend. I went out and bought a alpine for 150 and went to put it in and it didnt work i tried everthing. Thought it was the headunit so i put the stock one in and it only light up the dials and numbers not the screen
Old Jan 11, 2010 | 08:07 PM
mak330's Avatar
my guess is either you have wires crossed or possibly need a new metra connector. i belive **** hold on i have to remember this site that might help out.
Old Jan 11, 2010 | 08:11 PM
mak330's Avatar
http://www.installer.com/cars/
just look up your make and model and go to the very bottom its should guide you through making the connections.
Old Jan 11, 2010 | 08:14 PM
mak330's Avatar
hope that helps if not id take it back for an exchange
