LOW volume on new head unit
Old Mar 30, 2013 | 12:18 PM
tnl95's Avatar
Default LOW volume on new head unit
I just installed a new pioneer head unit into my 2001 monte ss, it works, but in order to hear anything at all, the audio has to be turned up all the way. I also installed an Axxess GMOS-04(Wiring harness- onstar and door chime) and a Axxess ASWC (steering wheel controls). Any help with why the volume would be so low?
Old Mar 31, 2013 | 10:48 PM
NovaSS369's Avatar
You may need to use the GMOS-01 surprisingly. There is a blue adjuster on the GMOS though. Turn that up with it unplugged and then plug it back in and see if that helps.
Old Apr 1, 2013 | 08:20 AM
tnl95's Avatar
Yeah, as it turns out, I ordered the GMOS 01, but I didn't get it. Instead they sent me the GMOS 04 inside the GMOS 01 packaging. Hopefully with the GMOS 01 it will work just fine.
Old Apr 1, 2013 | 11:21 AM
NovaSS369's Avatar
Should, I've had this problem before on 04+ GP's, 00+ Montes, Silverados, etc.
Old Apr 1, 2013 | 11:25 AM
NovaSS369's Avatar
Do you have an amplifier in the trunk between your 6x9's?
Old Apr 2, 2013 | 08:36 AM
tnl95's Avatar
Nope, no amplifier, which is why the GMOS 01 is the one I need
Old Apr 2, 2013 | 11:21 AM
NovaSS369's Avatar
Exactly, good luck!
Old Apr 3, 2013 | 09:22 AM
tnl95's Avatar
Okay, the GMOS 01 is in, and it works just fine! Thanks for all the help!
Old Apr 4, 2013 | 07:18 AM
owens91's Avatar
wait i have an amp and crutchfield recommended the gmos 04 will i have the same problem?
Old Apr 4, 2013 | 07:19 AM
owens91's Avatar
did you have a shop install this stuff or diy? im wondering how hard it will be because im going to be doing mines pretty soon as well, jus need to decide on a new radio
